Your terminal or terminal
emulator is correctly configured
emulator has the correct settings:
115200
baud for all ExtremeSwitching Universal switches
8 data bits
1 stop bit
no parity
XON/OFF flow control
enabled
For console port access, you might need to press [Return] several times before the welcome
prompt appears.
The SNMP Network Manager cannot
access the device:
Check that:
The SNMP access is enabled for the system.
The device IP address, subnet
mask, and default router are correctly configured, and that the device has
been reset.
The device IP address is
correctly recorded by the SNMP Network Manager (refer to the user
documentation for the Network Manager).
The community strings
configured for the system and Network Manager are the same.
The SNMPv3 USM, Auth, and
VACM configured for the system and Network Manager are the same.
The Telnet workstation cannot
access the device:
Check that:
been reset.
You entered the IP address of
the switch correctly when invoking the Telnet facility.
Telnet access is enabled for
the switch.
If
you attempt to log in and the maximum number of Telnet sessions
are being used, you should receive an error message indicating so.
Traps are not received by the
SNMP Network Manager:
Check that the SNMP Network
Manager's IP address and community string are correctly configured,
and that the IP address of the Trap Receiver is configured properly
on the system.
The SNMP Network Manager or Telnet
workstation can no longer access the device:
Check that:
Telnet access or SNMP access
The port through which you
are trying to access the device has not been disabled. If it is enabled,
check the connections and network cabling at the port.
are trying to access the device is in a correctly configured
VLAN.
configured for the device and the Network Manager are the same.
Try accessing the device
through a different port. If you can now access the device, a problem with
the original port is indicated. Re-examine the connections and cabling.
A network problem might be preventing you from accessing the device over the network. Try
accessing the device through the console port.
Permanent entries remain in the
FDB:
If you have made a permanent entry in the FDB that requires you to specify the VLAN to which the entry belongs and then deleted
the VLAN, the FDB entry remains. Although this does not harm the system, if you want
to removed the entry, you must manually delete it from the FDB.
Default and static routes:
If
you have defined static or default routes, those routes remain in
the configuration independent of whether the VLAN and VLAN IP address
that used them remains. You should manually delete the routes if
no VLAN IP address is capable of using them.
You forget your password and
cannot log in:
If you are not an administrator, another
user having administrator access level can log in, delete your user
name, and create a new user name for you, with a new password.
Alternatively,
another user having administrator access level can log in and initialize
the device. This will return all configuration information (including
passwords) to the initial values.
In the case where no one
knows a password for an administrator level user, contact your supplier.
