You can join or merge two stacks to create one larger stack. However,
the maximum number of nodes in an active topology is eight.
The operation performed when two stack segments are joined together
depends on the following factors:
Whether a slot number is duplicated
Whether both stacks have master nodes
The states of the nodes in each stack
If the nodes are configured with stacking enabled, one of the
following occurs:
If two segments are joined, both have operational masters,
and at least one of the nodes in one of the stacks duplicates a slot number of a
node in the other stack, the join is allowed. The link that has just connected
the two stacks shows as Inhibited. This prevents accidental stack joins. In this
condition, the nodes on the joined segment can still be reconfigured centrally
for stacking.
and all nodes have assigned slot numbers that are unique in both stacks, the
dual master situation is automatically resolved.
If two segments are joined, there are no duplicate slot
numbers, one of the segments has a master and a backup node, and the other
segment does not have either a master or a backup node, the nodes in this
segment are acquired by the master node. These nodes become standby nodes in the
stack.
The nodes that are not configured for stacking do not attempt to join the
active topology but join the stack anyway.
Any nodes enabled for stacking that are isolated between nodes (that are
not enabled for stacking) attempt to form an isolated active topology.
If one of the nodes that is not configured for stacking is then
configured for stacking and restarted, the behavior is as if two
active stacks were joined.
