Upgrading your ExtremeXOS image and modules uses the following process:
Beginning with ExtremeXOS 16.1, there are two methods available for the upgrade process:We recommend upgrading ExtremeXOS images and any modular packages at the same time. The following example shows the ExtremeXOS image summitX-15.7.1.4.xos being installed before rebooting the switch.
# show switch SysName: DUT1 SysLocation: SysContact: support@extremenetworks.com, +1 888 257 3000 System MAC: 00:04:96:97:D1:7B System Type: X460G2-48t-10G4 SysHealth check: Enabled (Normal) Recovery Mode: All System Watchdog: Enabled Current Time: Wed Feb 8 17:48:45 2017 Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC. Boot Time: Mon Feb 6 19:36:52 2017 Boot Count: 108 Next Reboot: None scheduled System UpTime: 1 day 22 hours 11 minutes 53 seconds Current State: OPERATIONAL Image Selected: primary Image Booted: primary Primary ver: 22.2.0.43 Secondary ver: 22.2.0.41 Config Selected: primary.cfg Config Booted: primary.cfg Config Automatic: NONE primary.cfg Created by ExtremeXOS version 22.2.0.41 499811 bytes saved on Mon Feb 6 19:36:12 2017 # download image 10.68.9.7 summitX-15.7.1.4.xos primary Debug information files are present in internal-memory. These files will be removed if you continue with download. Do you want to continue with download and remove existing files from internal-memory? (y/N) Yes Do you want to install image after downloading? (y - yes, n - no, <cr> - cancel) Yes Downloading to Switch.................................................................... Installing to primary partition! Installing to Switch............................................................................ Image installed successfully This image will be used only after rebooting the switch! # reboot Are you sure you want to reboot the switch? (y/N) Yes
Section contents:
