Integrated Application Hosting (IAH) has the following limitations:
A maximum of two CPU cores can be dedicated to VMs.
Multiple guest VMs per dedicated port
is not supported.
On stacks, the VMs do not migrate to backup with a failover. You will
need to restore the original master as master to access your VMs again.
Only OVA, qcow2, and any
QEMU-compatible files are supported. Compatibility issues might occur when using
third-party OVA files. The image formats VMDK and qcow2 are generally more reliable
than third-party OVA files.
You cannot rename a VM after creating it.
VNC servers are only
accessible using SSH tunnel for security reasons.
VNC support is not
available on non-primary stack nodes.
