We recommend that you enable CPU DoS protect in combination with this feature to make sure the CPU is not flooded with mirrored Kerberos packets in the event of a DoS attack on Kerberos TCP/UDP ports. If the rate limiting capability is leveraged on capable platforms, it is applied on CPU mirrored packets.Kerberos snooping is enabled when you enable identity management.
Kerberos identities are not detected when both server and client ports are added to identity management.Section contents:
