ExtremeXOS allows you to collect sFlow statistics on a per port basis.
An agent residing locally on the switch sends data to a collector that resides on another machine. You configure the local agent, the address of the remote collector, and the ports of interest for sFlow statistics gathering. You can also modify default values for how frequently on an average a sample is taken and the maximum number of samples allowed before throttling the sample gathering.
To configure sFlow on a switch:
Optionally, you may also change the default values of the following items:
Use the following commands to configure the sFlow feature:
The keyword options enable you to configure sFlow types on a given set of ports. If you do not configure an sFlow type, then ingress sFlow sampling is enabled as the default configuration.
Use the following commands to display the type of sFlow configured on the physical interface, and various statistics about sFlow sampling:
The following fields are displayed:
Section contents:
