This section provides a sample TACACS+ client configuration that:
All other client configuration features use the default settings as described Configuring the TACACS+ Client for Authentication and Authorization or in the ExtremeXOS v33.2.1 Command References .
configure tacacs primary server 10.201.31.238 client-ip 10.201.31.85 vr "VR-Default" configure tacacs primary shared-secret purple configure tacacs secondary server 10.201.31.235 client-ip 10.201.31.85 vr "VR-Default" configure tacacs secondary shared-secret purple enable tacacs
To display the TACACS+ client configuration, use the show tacacs command. Below is sample output from this command:
TACACS+: enabled TACACS+ Authorization: disabled TACACS+ Accounting : disabled TACACS+ Server Connect Timeout sec: 3 Primary TACACS+ Server: Server name : IP address : 10.201.31.238 Server IP Port: 49 Client address: 10.201.31.85 (VR-Default) Shared secret : purple Secondary TACACS+ Server: Server name : IP address : 10.201.31.235 Server IP Port: 49 Client address: 10.201.31.85 (VR-Default) Shared secret : purple TACACS+ Acct Server Connect Timeout sec: 3 Primary TACACS+ Accounting Server:Not configured Secondary TACACS+ Accounting Server:Not configured
