All switches can use hardware forwarding when the route mask is 64 bits or
less. If the route mask is greater that 64 bits, limitations apply based on the hardware
platform.
This support was added in ExtremeXOS Release 12.4 by using some of the
slices previously used for ACL support to create a Greater Than
64 Bit (GT64B) table. The GT64B table stores only those routes with a mask greater than 64
bits. When IPv6 forwarding is enabled, the switch behavior is as follows:
Fewer slices are available for ACLs.
Use show access-list usage acl-slice to check if any slice is
unused. If no slice is available, consider disabling a feature that is consuming ACL
slices if that feature is not required. Features that are enabled by default such as
IGMP Snooping or MLD Snooping can be disabled to free up
ACL resources if not required.
Table-full messages appear when there is no more space in the GT64B
table.
If an eligible route cannot be added to the GT64B table (because the
table is full), there is no guarantee that traffic for that route will be properly
routed.
If enabled, route compression for IPv6 can make room for additional
routes by reducing the number of entries in the GT64B table.
When an IPv6 address with a mask greater that 64 bits is configured
on a VLAN or tunnel, that address is automatically added to
the GT64B table.
All switches support hardware forwarding routes with masks
greater than 64 bits. For number of routes supported, see the limits for the particular switch
in the ExtremeXOS Release Notes.
Starting with ExtremeXOS 22.5, the
ipv6-mask-length option provides greater
hardware route scale and IP route sharing (ECMP) support for IPv6 “long-mask routes”,
meaning IPv6 subnets with mask lengths 65–128 bits. This provides additional scale and
resilience for IPv6 host routes whose mask length is 128 bits. Increasing scale and providing
ECMP for IPv6 mask 65–128 routes decreases IPv4 route scale. The default IPv6 mask length is
64.
The configure forwarding internal-tables [ l2-and-l3 | more [l2 | l3-and-ipmc | routes {ipv6-mask-length [64 | 128]}]] command provides the ability to support additional L2 and
L3 hosts, routes, or multicast table entries.
This support was added in ExtremeXOS Release 12.4 by using a
hardware table designed for this purpose. When IPv6 forwarding is
If no space is available in the hardware table, there is no guarantee that
traffic for that route will be properly routed.
If enabled, route compression for IPv6 can make room for additional routes
by reducing the number of entries in the hardware table.
When an IPv6 address with a mask greater that 64 bits is configured on a
VLAN or tunnel, that address is automatically added to the hardware table.
