Automatically Adding or Replacing Nodes in a
Stack
You can easily automatically add or replace nodes in an existing stack.
Important
You can only
replace a switch with the same switch model, or with a model from the same switch series
(family) with the same number of ports, but a different port type. For example, you can
replace an ExtremeSwitching
X450-G2-24t-10GE4 with an ExtremeSwitching X450-G2-24p-10GE4 (24t → 24p).
Connecting a new node to a stack automatically triggers the following tasks in a
stack:
Adds New Nodes—When a new
switch is connected to a stack, the switch is automatically:
Configured with the proper
stacking support parameters needed to bring up either native or
alternate stack ports. This automatic configuration (auto-discovery) is
supported on ExtremeSwitching X440-G2, X450-G2,
and X460-G2 series switches beginning in ExtremeXOS 30.3. Switches other than the ones listed above
require that you configure stacking support on the stacking ports
manually.
Assigned the lowest
available slot number.
Set as stacking
master-capability if the stack has only one master-capable switch (the
master itself) and the switch is directly connected to the current stack
master. Otherwise, the new switch is not made master-capable.
Assigned the stack MAC
address.
Rebooted, which then causes the new node to
join the stack.
Incompatible ExtremeXOS Check—Checks for and resolves incompatible ExtremeXOS software versions of stack nodes. If the new switch is
running an incompatible version, the version is reconciled by running the synchronize {slotslotid} command for that switch
causing the new switch to align with the stack master.
You cannot automatically
update a switch running ExtremeXOS 30.2 or
earlier to ExtremeXOS 30.3 or
later due to a file system compatibility issue. If a switch has ExtremeXOS 30.2 or earlier, prior to inserting the switch into the
stack topology, you need to manually upgrade the switch (see Upgrading the Software on all Active Nodes).
License Mismatch
Check—Checks for and resolves software license mismatches between all
master-capable nodes. The following command is issued: configure stacking {node-addressnode-address | slotslot-number} license-levellicense_restriction.
License mismatches due to
installing feature licenses cannot be resolved automatically. The node is
left in the failed state.
To start automatic node replacement:
Prepare the replacement node:
If the replacement switch is not out of the shipping box, remove any
configuration and restore the factory defaults by running the command
unconfigure switch {all | erase [all | nvram]} with the all option.
If the replacement switch is going to be the backup node, check for feature
license mismatches between it and the master by running show licenses {[slotslot |all]} {detail} on both switches.
Install licenses as needed to the replacement node by running the
command enable license {software} [key ] or;
install
license filefilename for universal platforms.
Power down the replacement switch.
Remove the current node from the stack.
If you are changing to a different port type (for example, 24t → 24p):
On the master, run the command configure slot slotmodulemodule_type, and change the module_type as applicable.
Save the configuration (save configuration {primary | secondary | existing-config | new-config}
Physically connect the new switch to the
stack, and power it up. For information about cabling, see the hardware
installation guide for your switch.
Configure the switch port and
speed for stack communication on the connected port of the new node for ExtremeSwitching X465, X695 series switches by
running the command configure stacking-support
stack-port
[stack-ports |
all] selection [native {V40 |
V80
| V160 | V200 | V320 | V400 {alternative-configuration | help}} |
alternate].
For ExtremeSwitching X460-G2, X450-G2,
X440-G2 series switches, the auto-discovery feature automatically turns on
stacking support for the connected port.
Platform
Stacking Mode
Supported Ports
Stacking Method
Port Speed
X460-G2
Native
VIM-2Q
V160
40G
VIM-2SS
10G
Alternate
VIM-2X
10G
Front panel
10G
X440-G2
Alternate
Front/rear panel
10G
X450-G2
Alternate
Front panel
10G
Important
The auto-discovery
feature takes between 5 and 10 minutes to complete. During this
time, the new node is rebooted twice, and if an image upgrade is
required, it is rebooted a third time.
To determine that the
auto-discovery feature has finished adding the node to the stack, on the
master run the command show slot {slot {detail} | detail } without the
detail options. When auto-discovery is finished, the slot
appears in the output as "Operational". If the node appears as "Failed",
run the command show slot {slot {detail} | detail }, specifying the
slot and using the detail
option to see why the node has failed to join the stack. The most likely
problem is that there is a feature license mismatch. To resolve this,
re-run the procedure ensuring that you complete Step 1b.
Auto-discovery
is enabled by default. To turn on or off auto-discovery, use the
following command: configure stacking-supportauto-discovery [disable | enable].
