You can specify multiple, single, or zero match conditions. If you do not
specify a match condition, all packets match the rule entry. Commonly used match
conditions are:
ethernet-destination-address
[mac-address | pre-defined-mac ]
mask—Ethernet destination address and mask
ethernet-type value {maskvalue}—Ethernet type, accepts an optional mask.
source-address prefix—IP source
address and mask
destination-address prefix—IP
destination-physical-port—supported in ingress
destination-port value {maskvalue}—IP destination port, accepts optional mask
source-port [value {maskvalue}|range]—TCP or UDP source port with optional mask or TCP or
UDP source port range
destination-port [port {maskvalue} |range]—TCP or
UDP destination port with optional mask or TCP or UDP destination port range
ttl value {maskvalue}—condition with optional mask that matches IPv4
Time-To-Live and IPv6 Hop Limit.
ip-tos value {maskvalue}—this condition accepts
optional masks
vlan-format—matches packets based on their VLAN format. Can be one of the following values:
untagged—all untagged packets
single-tagged—all packets with only a single tag
double-tagged—all packets with a double tag
outer-tagged—all packets with at least one tag; for
example, single tag or double tag
fragments—matches any fragment of fragmented packet, including the
first fragment
first-fragments—matches only the first fragment of a fragmented
packet.
l4-match valueoffsetoffsetmaskmask
value—generic bit-matching pattern starting at the Layer 4 header of
four separate chunks of 32-bits, each fully bit-maskable with a unique offset.
Unlike others, this match criteria can appear up to four times in a single rule,
each specified as a logical AND, to match up to four separate chunks of 32-bits.
Each chunk is fully bit-maskable with a unique offset. The matching data must be
within the first 128 bytes of the packet. This match criteria is intended for
advanced users only.
value—32-bit
value
offset—number
of bytes from the start of the Layer 4 header (for example, TCP header)
mask—32-bit
mask value applied to value for
matching. Mask is optional. The default is 0xffffffff.
On ExtremeSwitching X440-G2 series switches,
l4-match cannot be combined with other Layer 3 match criteria, such as
source-address.
