configure lldp transmit-delay
configure lldp transmit-delay [ auto | seconds]
Description
Configures the delay time between successive frame transmissions initiated by a value change or status change in any of the LLDP local systems Management Information Base (MIB).
The auto option uses a formula (0.25 * transmit-interval) to calculate the number of seconds.
Syntax Description
auto Uses the formula (0.25 * transmit-interval) to calculate the seconds.
seconds Specifies the interval at which LLDP notifications are sent. The range is 1 to 8291.
Default
2 seconds.
Usage Guidelines
This is the timer between triggered updates.
The following command configures the delay between LLDP frame transmissions for triggered updates to be automatically calculated:
configure lldp transmit-delay auto
Platform Availability
