Disables PoE, and perpetual PoE to all ports; or fast PoE to all ports, or selected ports, for some platforms.
fast | Disables delivery of PoE power to devices at the time of switch power on without waiting for boot up based on last saved PoE state. The default is disabled. |
ports | For fast PoE, specifies selecting ports. ExtremeSwitching X465 series switches only. |
port_list | For fast PoE, specifies the port list separated by a comma or -. ExtremeSwitching X465 series switches only. |
all | For fast PoE, specifies selecting all ports. ExtremeSwitching X465 series switches only. |
perpetual | Disable preserving PoE power delivery to devices during reboot. Perpetual PoE is a switch-wide setting. The default is disabled. |
You can control whether inline power is provided to the system by using the disable inline-power command and the enable inline power command. Using the disable inline-power command shuts down inline power currently provided on the entire switch or to specified ports and slots. Disabling inline power to a switch, port, or slot immediately removes power to any connected PDs. By default, inline power provided to all ports is enabled. Additionally, you can disable delivery of PoE power to devices at the time of switch power on without waiting for boot up (fast PoE) based on last saved PoE state. Per-port fast PoE is available on certain platforms. You can also elect to not preserve PoE power delivery to devices during reboot (perpetual PoE). The default for both PoE options is disabled.
Disabling inline power using the disable inline-power command does not affect the data traffic traversing the port. And, disabling the port using the disable port command does not affect the inline power supplied to the port.Note
Inline power cannot be delivered to connected PDs unless the switch is powered on.The following command shuts down inline power currently provided to all ports and all slots:
# disable inline-power perpetual
The following example turns off fast PoE for ports 1,2, and 5:
# disable inline-power fast ports 1,2,5
This command was first available in ExtremeXOS 11.1.
The fast and perpetual PoE options were added in ExtremeXOS 30.3.
Per-port fast PoE was added for ExtremeXOS 31.1.
This command is available on the PoE devices listed in Extreme Networks PoE Devices in the ExtremeXOS v33.2.1 User Guide .
The fast and perpetual options are only available on the ExtremeSwitching X435; and X465 (per port) series switches.
