enable iproute ipv6 compression
enable iproute ipv6 compression {vr vrname}
Description
Enables IPv6 route compression.
Syntax Description
vrname Specifies a VR or VRF.
Default
If no VR name is specified, the current CLI context is used.
Usage Guidelines
This command enables IPv6 route compression for the VR. This command applies a compression algorithm to each IPv6 prefix in the IPv6 prefix database.
The following example enables IPv6 route compression in the current VR context.
This command was first available in ExtremeXOS 12.0.
Default changed to enabled in ExtremeXOS 15.6.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the ExtremeXOS v33.2.1 Licensing Guide document.
