Configure MTU for Physical Ports
You can configure the MTU (maximum transmission unit) at the physical port level for Layer 2, IPv4, and IPv6.
In SLX-OS, you can use the show interface ethernet command to see the MTU configuration for an interface.
Run the efa inventory device interface set-mtu command.
# efa inventory device interface set-mtu --ip 10.x.x.x
--if-type eth --if-name 0/11,0/12 --mtu 1600 --ip-mtu 700 --ipv6-mtu 1800
Interface MTU Successfully Updated
| ID  | Name | Interface Type | MTU  | IP MTU | IPv6 MTU |
| 99  | 0/11 | ethernet       | 1600 | 1700   | 1800     |
| 102 | 0/12 | ethernet       | 1600 | 1700   | 1800     |
Interface MTU Details
--- Time Elapsed: 42.769852714s ---
This example configures the MTU for two Ethernet interfaces for IP address 10.x.x.x.
