There are four steps to configuring a
			Non-Clos Small Data Center topology; Create the fabric, Register the devices, Validate
			and Add the devices, and Provision the configuration on the devices. The following steps
			describe how to configure a small data center topology.
				Create the Fabric.
					$ efa fabric create --name extr-fabric  --type non-clos
				Add a device or devices to the
					Fabric. The user must provide device credentials as part of this command if the
					devices are not already registered with the inventory.
					$ efa fabric device add --name extr-fabric --ip 10.24.80.134 --rack room1-rack1 --username admin --password password
$ efa fabric device add --name extr-fabric --ip 10.24.80.135 --rack room1-rack1 --username admin --password password
$ efa fabric device add --name extr-fabric --ip 10.25.225.163 --rack room1-rack2 --username admin --password password
$ efa fabric device add --name extr-fabric --ip 10.25.225.167 --rack room1-rack2 --username admin --password password
 A device must be registered
					with Inventory Service before being added to a Fabric. Fabric Service supports
					IP numbered configuration. Each interface on a link between leaf and spine is
					assigned an IP address. eBGP peering use these IP addresses.  Multiple devices can be added to an
					existing fabric using the  efa fabric device add-bulk command. If a username and password are
					provided, then the devices will be auto registered with the inventory service.
					 $ efa fabric device add-bulk --name extr-fabric --rack room1-rack1 --ip 10.24.80.134,10.24.80.135 --rack room1-rack2 --ip 10.25.225.163,10.25.225.167
				Use the efa fabric configurecommand to validate and configure the Fabric Topology.
					$ efa fabric configure --name extr-fabric
 During each of the steps; create, add,andconfigure,
					Clos topology validations are performed. If the validation contains errors, the
					errors are reported to the user. The encountered Fabric topology errors can be
					exported to a CSV or DOT file.
 If the addition of devices to a
					Fabric is successful, then the configuration is pushed to all the devices of the
					Fabric using the efa
						fabric configurecommand above.
Use the following commands to display
			detailed information about the Small Data Center topology and configuration.
				- efa fabric export: Export fabric details to a .CSV file.
- efa fabric show: Display the details of the fabric.
- efa fabric topology show physical: Displays physical
					connectivity of the devices in a fabric.
- efa fabric topology show underlay: Displays the underlay
					connectivity - the BGP neighborship and the state of BGP sessions of the devices
					in a fabric.
- efa fabric topology show overlay: Displays the overlay
