| EFA Config |
ip anycast-gateway-mac 0201.0101.0101 |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch does not contain the configuration, push the new configuration. |
| EFA Config |
| Switch Config |
ip anycast-gateway-mac 0301.0101.0101 |
| Case | CONFLICT Config |
| Action | REMOVE and PUSH Config |
| Remarks | If the switch contains conflicting configuration, remove the existing configuration and push the new configuration. |
