| EFA Config |
evpn fabric-2 route-target both auto ignore-as rd auto duplicate-mac-timer 5 max-count 3 ! |
| Switch Config | Empty |
| Case | MISSING Parent Config |
| Action | PUSH Entire Config |
| Remarks | If the switch does not contain the evpn config of the name intended, push the intended efa config. |
| EFA Config |
| Switch Config |
evpn fabric-3 route-target both auto ignore-as rd auto duplicate-mac-timer 7 max-count 5 vlan add 100 ! |
| Action | REMOVE Parent and PUSH Entire Config |
| Remarks | If the switch does not contain the intended evpn config and contains a different name, remove the existing evpn config and push the intended evpn config. |
| EFA Config |
| Switch Config |
evpn fabric-2 vlan 200 ! |
| Case | MISSING Child Config |
| Action | MERGE Config |
| Remarks | If the switch contains additional configuration pushed by the tenant, but does not contain all the intended child configurations, merge the configurations. |
| EFA Config |
| Switch Config |
evpn fabric-2 route-target both auto ignore-as rd auto duplicate-mac-timer 7 max-count 5 vlan add 100 ! |
| Case | CONFLICT Child Config |
| Action | PUSH Child Config |
| Remarks | If the switch contains conflicting evpn config, replace the config with the intended config.. |
