| EFA Config |
ip mtu 9100 |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch configuration does not contain mtu config, push the new configuration. |
| EFA Config |
ip mtu 9100 |
| Switch Config |
ip mtu 8999 |
| Case | CONFLICT Config |
| Remarks | If the switch configuration contains conflicting config, remove the existing configuration and push the new configuration. |
