Upgrade MCT Leaf Pair with Dual Homed
Servers in Clos
Enabling maintenance mode on an
MCT leaf involves BGP and MCT/NSM. The graceful_shutdown parameter will be sent
out to all the leaf‘s underlay neighbors (all spines in the pod). The neighbors
will no longer send traffic to the MCT leaf going into maintenance mode and
redirect traffic from spines to the peer MCT leaf. MCT will instruct the peer
leaf to become the designated forwarder, ICL will be shut down, and CCE ports
for clients will also be shut down. Traffic from dual-homed servers will be
redirected to the peer leaf. With maintenance mode enabled, traffic is
completely redirected to the peer leaf.
The running-configuration is
saved on the first MCT leaf to preserve all current configurations including the
maintenance mode enable configuration.
The firmware on the MCT leaf can
now be upgraded and rebooted for firmware activation without traffic loss.
After the firmware is upgraded,
the maintenance mode is disabled to allow traffic again through the upgraded MCT
leaf.
The running-config is saved again to ensure the maintenance mode config remains
disabled.
The same process can be carried out on the second MCT leaf to upgrade the
firmware without traffic loss.
First MCT leaf firmware upgrade with maintenance mode
Second MCT leaf firmware upgrade with maintenance mode
