Change a Physical Port State
You can bring a physical port administratively up or down.
In SLX-OS, you can use the show interface ethernet command to see the status of the Ethernet interfaces on your device.
Run the efa inventory device interface set-admin-state command.
# efa inventory device interface set-admin-state
--ip 10.x.x.x --if-type eth --if-name 0/31,0/32 --state up
Admin-State Updated Successfully
| ID | Name | Interface Type | Admin Status |
| 51 | 0/32 | ethernet       | up           |
| 15 | 0/31 | ethernet       | up           |
Interface Details
--- Time Elapsed: 18.235185378s ---
This example brings two Ethernet ports into the up state.
