Clos Fabric with Auto VNI Map
Multi Tenancy
EFA supports multi tenancy by allowing multiple tenants to have overlapping ctags and non-overlapping L2VNI. A tenant ctag will get a unique L2VNI and a unique network allocated in the fabric
The following example shows a multi tenancy configuration.
efa tenant create --name tenant11 --vrf-count 10 --vlan-range 2-4090 --port 10.24.80.134[0/15-17],10.24.80.135[0/15-17],10.25.225.11[0/15-17],10.25.225.46[0/15-17],10.24.85.74[0/15-17],10.24.85.76[0/15-17] --description Subscriber1
efa tenant show
|   Name   | L2VNI-Range | L3VNI-Range | VLAN-Range | VRF-Count | Enable-BD |         Ports         |
| tenant11 |             |             | 2-4090     | 10        | False     | 10.24.85.74[0/15-17]  |
|          |             |             |            |           |           | 10.24.80.135[0/15-17] |
|          |             |             |            |           |           | 10.25.225.11[0/15-17] |
|          |             |             |            |           |           | 10.25.225.46[0/15-17] |
|          |             |             |            |           |           | 10.24.80.134[0/15-17] |
|          |             |             |            |           |           | 10.24.85.76[0/15-17]  |
efa tenant create --name tenant12 --vrf-count 10  --vlan-range 2-4090 --port 10.24.80.134[0/18-20],10.24.80.135[0/18-20],10.25.225.11[0/18-20],10.25.225.46[0/18-20],10.24.85.74[0/18-20],10.24.85.76[0/18-20]
Tenant Creation Failed:
         Vlan (2) overlaps with Tenant (tenant11)
efa tenant create --name tenant21 --vrf-count 10 --enable-bd --port 10.24.80.134[0/21-25],10.24.80.135[0/21-25],10.24.85.74[0/21-25],10.24.85.76[0/21-25],10.25.225.11[0/21-25],10.25.225.46[0/21-25]
efa tenant create --name tenant22 --vrf-count 10 --enable-bd --port 10.24.80.134[0/26-30],10.24.80.135[0/26-30],10.24.85.74[0/26-30],10.24.85.76[0/26-30],10.25.225.11[0/26-30],10.25.225.46[0/26-30]
efa tenant show
| tenant11 |             |             | 2-4090     | 10        | False     | 10.25.225.46[0/15-17] |
| tenant21 |             |             | 2-4090     | 10        | True      | 10.24.85.74[0/21-25]  |
|          |             |             |            |           |           | 10.25.225.11[0/21-25] |
|          |             |             |            |           |           | 10.25.225.46[0/21-25] |
|          |             |             |            |           |           | 10.24.80.134[0/21-25] |
|          |             |             |            |           |           | 10.24.85.76[0/21-25]  |
|          |             |             |            |           |           | 10.24.80.135[0/21-25] |
| tenant22 |             |             | 2-4090     | 10        | True      | 10.24.85.76[0/26-30]  |
|          |             |             |            |           |           | 10.25.225.11[0/26-30] |
|          |             |             |            |           |           | 10.24.80.135[0/26-30] |
|          |             |             |            |           |           | 10.25.225.46[0/26-30] |
|          |             |             |            |           |           | 10.24.85.74[0/26-30]  |
|          |             |             |            |           |           | 10.24.80.134[0/26-30] |
efa tenant epg create --name epg11 --tenant tenant11 --po po1115,po1215,po1315 --switchport-mode trunk --switchport-native-vlan 11 --ctag-range 11-12
efa tenant epg create --name epg21 --tenant tenant21 --po po2121,po2221,po2321 --switchport-mode trunk  --ctag-range 11-12
efa tenant epg create --name epg22 --tenant tenant21 --po po2122,po2222,po2322  --switchport-mode trunk  --ctag-range 11-12
efa tenant epg show
Tenant        : tenant11
Description   :
Ports         :
POs           : po1315, po1215, po1115
Port Property : switchport mode     : trunk
              : native-vlan-tagging : false
NW Policy     : ctag-range          : 11-12
Network Property [Flags : * - Native Vlan]
| Ctag | L2-Vni | Anycast-ip | BD-name |  Dev-state  |  App-state  |
| 11*  | 11     |            |         | provisioned | cfg-in-sync |
| 12   | 12     |            |         | provisioned | cfg-in-sync |
Tenant        : tenant21
Description   :
Ports         :
POs           : po2121, po2221, po2321
| 11   | 4099   |            | Auto-BD-4099 | provisioned | cfg-in-sync |
| 12   | 4100   |            | Auto-BD-4100 | provisioned | cfg-in-sync |
Tenant        : tenant21
Description   :
Ports         :
POs           : po2122, po2222, po2322
| 12   | 4102   |            | Auto-BD-4102 | provisioned | cfg-in-sync |
| 11   | 4101   |            | Auto-BD-4101 | provisioned | cfg-in-sync |
efa tenant epg create --name epg23 --tenant tenant21 --po po2122,po2322  --switchport-mode trunk  --ctag-range 21-22 --bridge-domain 21:Auto-BD-4101 --bridge-domain 22:Auto-BD-4102
efa tenant epg show
Tenant        : tenant11
Description   :
Ports         :
Tenant        : tenant21
Description   :
Ports         :
Tenant        : tenant21
Description   :
Ports         :
Tenant        : tenant21
Description   :
Ports         :
POs           :
NW Policy     : ctag-range          : 21-22
| 21   | 4101   |            | Auto-BD-4101 | provisioned | cfg-in-sync |
| 22   | 4102   |            | Auto-BD-4102 | provisioned | cfg-in-sync |
