The five-stage topology has three layers
of devices: Leaf, Spine, and Super Spine. All links between Leaf and Spine must be
connected. Spine nodes should not be interconnected. Similarly, all the links between the
Spine and Super-spine must be connected. A border Leaf can be directly connected to a
Super-spine, but there should not be any connection between a border Leaf and a
Spine.
There are four steps to configuring a
five-stage topology: create the fabric, register the devices, validate and add the
devices, and provision the configuration on the devices.
The following image is an
example of a five stage fabric. The following steps describe how to configure a
five-stage fabric topology.
Five-Stage Clos
Automation
5-stage Clos can be built top
to bottom or bottom to top. The following example builds from the top down.
Create the Fabric using the
efa fabric
create command.
Add a device or devices to the
5-stage Fabric using the efa fabric device add. The user must provide device credentials as
part of this command if the devices are not already registered with the
inventory.
A device must be registered with Inventory
Service before being added to a Fabric. Fabric Service supports IP numbered
configuration. Each interface on a link between Leaf and Spine is assigned an IP
address. eBGP peering uses these IP addresses.
Multiple devices can be
added to an existing fabric using the efa fabric device
add-bulk command. If a username and password are provided, then the
devices will be auto registered with the inventory service.
Use the efa fabric configure
command to validate and configure the Fabric Topology.
During the addition of a device to a Fabric
and during Fabric configuration, Clos topology validations are performed. If the
validation contains errors, the errors are reported to the user as a response to
the fabric device add or fabric configure
operations. Any Fabric topology errors can be exported to a CSV or DOT file.
The following topology
validations are performed:
Leaf nodes must connect
to all the Spine nodes.
A Spine node must connect to all the Leaf
nodes.
A Border Leaf node
connects to all the Spine nodes.
A Spine node connects to
all the Border Leaf nodes
No more than two Leaf
nodes connect to each other.
No more than two Border
Leaf nodes connect to each other.
Border Leaf node and Leaf node are not
connected to each other.
Spine nodes are not
Super-spine nodes are not
If a Leaf node is marked
as "multi-homed", then the node must have an MCT neighbor.
as "single-homed", then the node is not connected to other Leaf
nodes.
If a Border Leaf node is
marked as "multi-homed", then the node must have an MCT neighbor.
marked as "single-homed", then the node is not connected to other Border
Leaf nodes.
Device role (such as Leaf, Border-leaf,
Spine, and Super-spine) is validated for a given device platform type
(for example, SLX 9840 cannot be added as a leaf).
