| EFA Config |
interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.8/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch does not contain the intended configuration, push the configuration. |
| EFA Config |
| Switch Config |
interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.8/31 no shutdown ! |
| Case | MISSING Child Config |
| Action | PUSH Child Config |
| Remarks | If the switch does not contain the child configuration, push the child configuration. |
| EFA Config |
| Switch Config |
interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.8/31 bfd interval 500 min-rx 500 multiplier 6 no shutdown ! |
| Case | CONFLICT Child Config |
| Remarks | If the switch contains the conflicting child configuration, remove the conflicting child configuration and push the child configuration. |
| EFA Config |
Leaf 1 interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.8/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! Leaf 2 interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.9/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Switch Config |
Leaf 1 interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.20/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! Leaf 2 interface Port-channel 64 description MCTPeerInterface ip address 10.20.20.9/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Action | REMOVE Child Config, PUSH Child Config |
| Remarks | If the switch configuration contains conflicting child configuration in terms of invalid Pair IP between two leafs, remove the conflicting child configuration and push the child config with a valid Pair IP. |
