The following table describes information added to this guide for the Extreme Fabric Automation 2.2.0 software release.
| Feature | Description | Link |
| Data Consistency | This feature ensures that SLX devices have the correct configuration before allowing traffic. | Data Consistency |
| Redundant Management Network | This feature provides fault tolerance for the management path. | Redundant Management Network |
| RASlog Service | The RASlog service is aware of all devices that are registered with EFA services and processes events only from those devices. | RASlog Service |
| Supported Platform Matrix | New tables in this topic describe deployment models and supported TPVM versions. | Supported Platform Matrix |
| L3 Tenant Network Services | This feature supports IPv6 Anycast gateways; VRF backup routing, static routing, BFD static routing, local ASNs, and graceful restart; CEP reload delay, LACP timeout for port channels; centralized and distributed routing; and sharing resources across tenants. | Layer 3 Network Services |
| Security | New topics for user management (including RBAC enforcement), certificate management, and audit trail logging. | |
| SLX device configuration | New commands and topics to configure the SLX devices that EFA manages. | |
| Cluster tracking | New functionality to enable a CEP interface to track the state of MCT clusters. | Enable Cluster Tracking on CEP Interfaces |
| Running-configs | New command to display a list of current EFA running-configs. | Display EFA Running Configurations |
| Deployment | Updated installation and upgrade topics. | Install EFA in a Single-Node Deployment |
| NTP requirements | Improved the list of requirements | EFA Requirements |
For more information about this software release, see the Extreme Fabric Automation Release Notes.
