| EFA Config |
Leaf 1 Config interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.20/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! Leaf 2 Config interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.21/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config to the both the Leafs |
| Remarks | If the switch does not contain the intended configuration, push the configuration. |
| EFA Config |
| Switch Config |
Leaf 1 Config interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.20/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! Leaf 2 Config interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.24/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Case | CONFLICT Config |
| Action | Remove Child Config and PUSH Child Config |
| Remarks | If the switch Configuration on Leaf 2 does not have a valid IP Pair configuration, remove the child configuration and push the child configuration with a valid IP Pair. |
| EFA Config |
interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.20/31 bfd interval 400 min-rx 400 multiplier 5 no shutdown ! |
| Switch Config |
interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.20/31 no shutdown ! |
| Action | PUSH Config |
| Remarks | If the switch does not contain the intended configuration, push the new configuration. |
| EFA Config |
| Switch Config |
interface Ethernet 0/26 description Link to 10.24.48.133 Spine ip address 10.10.10.20/31 bfd interval 500 min-rx 500 multiplier 6 no shutdown ! |
| Case | CONFLICT Child Config |
| Action | PUSH Child Config |
| Remarks | If the switch contains conflicting child configuration, remove the existing child configuration and push the intended child configuration. |
