You can install EFA in a single-node, non-TPVM deployment.
Ensure you have configured NTP according to EFA Requirements.
sudoers privileges. $ source deployment.sh Step 1: Checking for EFA Stack ... 1) Single-node deployment 2) Multi-node deployment 3) Quit Enter your choice (1/2/3): 1 Single-node Deployment 1) Enable secure mode (https with http redirection) 2) Standard mode (http) 3) Quit Enter your choice (1/2/3): 1 Secure mode: yes Step 2: Installing EFA 2.2.0-14... Started checking system configuration... Checking required ports availability... Verifying if k3s services are running ... Unpacking images of EFA... Verifying if hostauth service are running ... Generating Unix user for EFA use... Saving EFA user information for this node (sam-kub-master)... Deploying EFA application... * Deploying core services * Deploying ecosystem services Extreme Fabric Automation Stack is now Deployed and Ready!
If the installation only partially succeeds, you can remove it using the source deployment.sh -o undeploy script from the /efa directory on the node where you installed EFA.
