In SLX 20.1.1, configuration management process maintains two databases.
SLX OS maintains a startup file which is an ASCII file saved in flash when running-config is copied to startup-config. The startup file can also be updated by any ASCII config from outside the switch. By default, when system reboots, the SLX OS replays the configuration from the Startup database. The user can modify the Startup file to replay the configuration if required. It is also done in some exception cases like firmware upgrade or DB corruption.
Maintenance mode can be enabled by configuring enable under system-maintenance configuration mode. If the configuration is persisted, the switch needs to be in maintenance mode before reloading for it to come back in maintenance mode.
In SLX 20.1.2, all the configurations are stored in one database which also persists.
Maintenance mode can be enabled by configuring enable-on-reboot under system-maintenance configuration mode. After the reboot, the switch comes back up in maintenance mode and remains operational.
SLX(config-system-maintenance)# enable-on-reboot SLX(config-system-maintenance)# [no] enable-on-reboot
The system maintenance turn-off command brings the system out of maintenance mode.
