Cluster Client reconciliation is supported only in SLX-OS releases earlier than SLX 20.1.1.
Configuration |
Details |
EFA Intended Config |
cluster nonclos-cluster-1 peer 10.20.20.7 peer-interface Port-channel 64 peer-keepalive auto ! member vlan all member bridge-domain all |
Switch Current Config |
cluster default-cluster-1 1 peer-interface Port-channel 64 peer 10.20.20.4 df-load-balance deploy client default-cluster-1 1 ! |
Action |
Partial Config, Merge Specific Config to Switch |
