| EFA Config |
overlay-gateway fabric-2 map vni auto activate ! |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch does not contain the intended configuration, push the new configuration. |
| EFA Config |
overlay-gateway fabric-2 ip interface Loopback 2 map vni auto activate ! |
| Switch Config |
overlay-gateway fabric-2 ip interface Loopback 2 map vlan 2000 vni 5000 map vni auto map bridge-domain 4095 vni 8100 activate ! |
| Case | No Change |
| Action | No Action |
| Remarks | If the switch configuration and the intended configuration are same, accept that the switch configuration has additional configuration. |
| EFA Config |
| Switch Config |
overlay-gateway fabric-2 ip interface Loopback 3 map vlan 2000 vni 5000 map vni auto map bridge-domain 4095 vni 8100 activate ! |
| Case | CONFLICT Child Config |
| Action | PUSH Child Config |
| Remarks | If the switch configuration and the intended configuration conflict with the child configuration, remove the existing child configuration and push the new child configuration. |
| EFA Config |
| Switch Config |
overlay-gateway fabric-2 ip interface Loopback 2 map vlan 2000 vni 5000 map bridge-domain 4095 vni 8100 activate ! |
| Case | MISSING Child Config |
| Remarks | If the switch does not have the child configuration, push the child configuration. |
