| EFA Config |
mtu 9216 |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch configuration does not contain mtu config, push the new configuration. |
| EFA Config |
mtu 9216 |
| Switch Config |
mtu 9316 |
| Case | CONFLICT Config |
| Remarks | If the switch configuration contain conflicting configuration, remove the existing configuration and push the new configuration. |
