Administrators can use EFA to integrate with several orchestration ecosystems.
EFA provides one-touch integration points with these ecosystems, providing deep insight into VMs, vSwitches, port groups, and hosts, and the translation of these into IP Fabric networking constructs.
| ML2 Plugin |
| Trunking (VLAN) | Trunking using virtio ports |
| SRIOV-VF | Network Operations using SRIOV-VF Passthrough – Intel, Mellanox |
| SRIOV-PF | Network Operations using SRIOV-VF Passthrough – Intel, Mellanox |
| Layer 3 (E-W) | East West Traffic using virtio ports (Neutron Router, Router Interface, Subnet CRUD operations) |
| VMotion | Virtual Machine Migration |
| BD Support | Support for BD-enabled in Tenant Service |
| Multi VIM Support | Multiple Tenants managed from OSS |
| Multi-Segment Support | Multiple segments using SRIOV (PF/VF)+ Virtio (DHCP) |
| CEP Support | Support for single-homed connections to the edge port |
