Logging and Log Files
Log directories vary by deployment type
and by application.
Logs are saved to the following locations:
- Non-TPVM EFA deployments:
/var/log/efa. The installation logs in the
/var/log/efa/installer directory are a good source for
discovering the reason for a failure.
- TPVM EFA deployments: /apps/efa_logs
- Kubernetes log files: /var/log/pods
The efa supportsave script
gathers all logs, database dumps, pod logs, and deployment details and then compresses
them into a ZIP folder. You can share this ZIP folder with Extreme support personnel
when troubleshooting an issue.
