| EFA Config |
ip router-id 172.31.254.20 |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch does not contain the configuration, push the new configuration. |
| EFA Config |
| Switch Config |
ip router-id 172.31.254.22 |
| Case | CONFLICT Config |
| Remarks | If the switch contains conflicting configuration, remove the existing configuration and push the new configuration. |
