Return Material Authorization
Return Material Authorization (RMA) allows replacement of a faulty switch with a new switch
with the same configuration.
RMA process comprises of the following steps:
- A faulty switch is replaced with a
new switch with same configuration.
- EFA engine
initiates the RMA process. The RMA process can be initiated manually using
REST/CLI.
- EFA engine uses the
config-backup taken by Switch Health Management and initiates the config-replay on
the replacement switch.
- After config-replay is complete, EFAengine uses Drift and Reconcile to bring in data
consistency.
