The following is an example of a notification payload.
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T04:53:04-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:53:04-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:admin desc=Userssh desc=connection methodThu May 28 12:09:04 2020 desc=last_successful_login_time BOMLogin information: User admin via ssh Last Successful Login Time : Thu May 28 12:09:04 2020. MessageID:SEC-1206 Module: Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T12:10:24.877106}","time":"2020-05-28T04:53:04-07:00"}
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T04:53:05-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:53:05-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:admin desc=User134.141.25.192 desc=IP address BOMLogin information: User admin Login successful via TELNET/SSH/RSH. IP Addr: 134.141.25.192. MessageID:SEC-1203 Module: Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T12:10:25.880126}","time":"2020-05-28T04:53:05-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:53:05-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:login desc=Event NameREMOTE, IP Addr: 134.141.25.192 desc=connection method and IP Address BOMEvent: login, Status: success, Info: Successful login attempt via REMOTE, IP Addr: 134.141.25.192. MessageID:SEC-3020 Module: Severity:INFO Hostname:SLX Username:admin Timestamp:2020-05-28T12:10:25.881575}","time":"2020-05-28T04:53:05-07:00"}
{"level":"info","msg":"Received an event APP_NTF.Task_Event.","time":"2020-05-28T04:40:04-07:00"}
{"level":"info","msg":"Handling TaskNotificationEvent: \u0026{EventHeader:{EventID:APP_NTF.Task_Event PublishTime:2020-05-28T04:40:04-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} AppName:fabric TaskName:EFA-000001 Scope:user Username:root Status:started DeviceIP: Message:Fabric create request received :request={\"FabricDescription\":\"\",\"FabricName\":\"test\",\"FabricStage\":3,\"Type\":\"clos\"}}","time":"2020-05-28T04:40:04-07:00"}
{"level":"info","msg":"Handling TaskNotificationEvent: \u0026{EventHeader:{EventID:APP_NTF.Task_Event PublishTime:2020-05-28T04:40:04-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} AppName:fabric TaskName:EFA-000002 Scope:user Username:root Status:succeeded DeviceIP: Message:Fabric create request success :request={\"FabricDescription\":\"\",\"FabricName\":\"test\",\"FabricStage\":3,\"Type\":\"clos\"}}","time":"2020-05-28T04:40:04-07:00"}
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T04:41:32-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:41:32-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:Ethernet 0/47 desc=InterfaceName BOM Interface Ethernet 0/47 is protocol down. MessageID:NSM-1002 Module:Interface Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T11:58:53.538052}","time":"2020-05-28T04:41:32-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:41:32-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:Ethernet 0/47 desc=InterfaceName BOM Interface Ethernet 0/47 is link down. MessageID:NSM-1003 Module:Interface Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T11:58:53.538078}","time":"2020-05-28T04:41:32-07:00"}
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T04:57:02-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:57:02-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:Port-channel 26 desc=InterfaceName BOM Port-channel 26 is created. MessageID:NSM-1004 Module: Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T12:14:22.133559}","time":"2020-05-28T04:57:02-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T04:57:02-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:database commit transaction desc=Event NameSucceeded desc=Command statusconfigure config interface Port-channel 26 desc=ConfD hpath string BOMEvent: database commit transaction, Status: Succeeded, User command: configure config interface Port-channel 26. MessageID:DCM-1006 Module: Severity:INFO Hostname:SLX Username:admin Timestamp:2020-05-28T12:14:22.224708}","time":"2020-05-28T04:57:02-07:00"}
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T05:00:47-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T05:00:47-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:Ethernet 0/40 desc=InterfaceName BOM Interface Ethernet 0/40 is administratively down. MessageID:NSM-1020 Module:Interface Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T12:18:07.943449}","time":"2020-05-28T05:00:47-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T05:00:47-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:Ethernet 0/40 desc=InterfaceName BOM Interface Ethernet 0/40 is link down. MessageID:NSM-1003 Module:Interface Severity:INFO Hostname:SLX Username: Timestamp:2020-05-28T12:18:07.946265}","time":"2020-05-28T05:00:47-07:00"}
{"level":"info","msg":"Received an event RAS.Event_Created.","time":"2020-05-28T05:00:48-07:00"}
{"level":"info","msg":"Handling RaslogEvent: \u0026{EventHeader:{EventID:RAS.Event_Created PublishTime:2020-05-28T05:00:48-07:00 Auth:{Basic:\u003cnil\u003e Token:\u003cnil\u003e}} DeviceIP:10.20.61.104 Message:database commit transaction desc=Event NameSucceeded desc=Command statusconfigure conf-if-eth-0/40 shutdown desc=ConfD hpath string BOMEvent: database commit transaction, Status: Succeeded, User command: configure conf-if-eth-0/40 shutdown. MessageID:DCM-1006 Module: Severity:INFO Hostname:SLX Username:admin Timestamp:2020-05-28T12:18:07.973754}","time":"2020-05-28T05:00:48-07:00"}
		Types of notifications can be Event, Alert or Task.
