If a new version of the EFA bundle is
required or if no EFA bundle is present, the EFA .tar file must be copied to the /efaboot directory.
Verify that the TPVM is set up for an EFA deployment.
Validate that the TPVM is running version 4.0.0 and that SLX-OS is
running with at least the minimum requirements.
# show tpvm status
# show version
# lsb_release -a
Validate that the TPVM has an assigned IP address.
Validate that the SSH keys are uploaded.
Validate that passwordless access is configured.
Confirm NTP on the TPVM.
# tpvm config ntp add server <ip>
Validate that NTP is synchronized.
If necessary, log in to TPVM and configure the NTP time zone.
# sudo timedatectl set-timezone your_time_zone
Determine whether more than one EFA version is available in the SLX /efaboot
directory.
- If no version is
available, the installer stops.
- If more than one version
is available, you have the option to pick a version.
- If only one version is
available, the installer picks up that version.
Determine whether the TPVM
already has a version of EFA installed.
- If the same version is
already installed, the installer stops.
- If no EFA is installed,
the installer continues with installation.
- If a different version is
detected, the upgrade or downgrade continues, depending on the detected
version.
Copy the EFA tar file to the SLX device.
# start-shell
# cd /efaboot
# scp <efa-bundle>
Deploy EFA on the TPVM from the SLX device.
Validate the upgrade.
Verify the status of
EFA.
Verify the status of the
Fabric.
tenant.
EPG (endpoint group).
If the output of the
commands indicates that any network is in cfg-refreshed
state, run the following commands.
- Run this command
for each device in the tenant:
efa tenant
debug device drift --device-ip <ip-address>
--reconcile
efa inventory
device update --fabric <fabric-name>
