| EFA Config |
cluster fabric-2-cluster-1 peer 10.20.20.9 peer-interface Port-channel 64 peer-keepalive auto ! |
| Switch Config | Empty |
| Case | MISSING Config |
| Action | PUSH Config |
| Remarks | If the switch does not contain the configuration, push the new configuration. |
| EFA Config |
| Switch Config |
cluster fabric-3-cluster-1 peer 10.20.20.9 peer-interface Port-channel 64 peer-keepalive auto ! |
| Case | MISSING Parent Config |
| Action | PUSH Entire Config |
| Remarks | If the switch does not contain the parent configuration, push the entire configuration. |
