IP Address Assignment
Table 1. IP Address Assignment Settings
FieldDescription
DHCPIndicates if a DHCP Server is used to assign the AP IP address. The server relies on the standard protocol known as Dynamic Host Configuration Protocol (DHCP) to respond to broadcast queries by clients.
When you select DHCP, the IP address fields display the server-assigned address information.
For more information about configuring a DHCP server, see the ExtremeCloud IQ Controller Deployment Guide.
StaticIndicates if a permanent IP address is assigned for this AP. After selecting Static, provide the information for the following address fields:
  • IP Address
  • Mask—Subnet Mask
  • Default Gateway
