To display your site location on a physical map from the Site workbench, provide site
metadata including map coordinates. To access Site metadata:
Go to Configure > Sites.
Select a site and select the Location tab.
Provide the following optional information:
Site Manager Name
Site Manager Email
Site Manager Contact
Region
City
Postal Code
Campus
Map Coordinates. The system automatically displays your
site location based on data in the geodatabase served
from your browser. You can also select a location on the map to populate the Map
Coordinates field, or type specific coordinates in this field.
Depending on where your sites are
located, the global map on the Sites list page will
zoom into that area. Site location is determined by the coordinates specified. The
zoom factor depends on the location of the sites.
