| Captive Portal Type | EGuest |
| Walled Garden
Rules | Select Walled Garden
Rules to configure policy rules for the external
captive portal. |
| ExtremeGuest Servers |
- Select the ExtremeGuest server from the drop-down list of configured servers. The
number of server fields depends on the number of configured servers. Configure
one portal server and up to two backup servers.
- Select an icon (
, , or
) to manage your servers from here. Select the
appropriate check box to indicate that the server handles
authentication, accounting, or both. At least one selection is required
for each server.
- Select Portal to
configure one server as the portal server. If your portal server goes
down, you must manually select a backup server as the portal
server.
