ExtremeCloud IQ Controller offers a power consumption widget for the AP5000 series access points. This widget offers a visual display of the power consumption for the AP over the display period.
| Power Status | High | Normal | Low | Normal |
| Power Source | 802.3BT | 802.3AT | 802.3AF | Power Supply |
| PSE= OFF | OFF | OFF | OFF All 3 Radios operate 2x2 Maximum Tx 10 dBm | OFF |
| PSE=Auto | ON | OFF | OFF | OFF |
| USB=OFF | OFF | OFF | OFF | |
| USB=Auto | ON | ON All 3 Radios operate 3x3 | OFF | ON All 3 Radios operate 4x4 |
The AP5020 power values differ from other 5000 series APs and legacy APs. The most restrictive power connection is listed instead of the highest level power connection. This is to support AP power redundancy. The level of service provided does not change if any of the power connections fails. For more details on the AP5020 power profile, refer to the Extreme Wireless 802.11be Wi-Fi 7 Indoor AP5020 Access Point Installation Guide.
The AP5050U and AP5050D access points do not include a USB port or an external power supply. These outdoor access points operate on standard power.
