| Field | Description |
| Network Name | Enter a unique, user-friendly value that makes sense for your business. Example: Staff |
| SSID | Enter a character string to identify the wireless network. Maximum 32 characters. Upper and lowercase allowed. Example: PermanentStaff |
| Status | Enable or disable the network service. Disabling the network service shuts off the service but does not delete it. |
| Auth Type | The Authorization Type for a CWA captive portal must be WPA2 Enterprise (802.1x EAP) |
| Enable Captive Portal | Select this option to configure a captive portal network. |
| MAC-Based Authentication | (Optional)
Select this option to enable MBA. When selected,
multi-factor authentication is enabled. The following
parameter displays when MAC-based Authentication is
enabled:
| Captive Portal Type | CWA |
| AAA Policy | Specify the AAA Policy associated with the captive portal. Define the RADIUS server used for authentication in the AAA Policy. This is the IP address of the captive portal. See CWA Network Settings. |
| Default Auth Role | Specify the default authorization role that is configured on ExtremeCloud IQ Controller. |
| Default VLAN | Specify the default VLAN that is configured on ExtremeCloud IQ Controller. |
