An internal captive portal resides on ExtremeCloud IQ Controller. Configure the following parameters for an internal captive portal.
| Field | Description |
| Portal name | Select an icon to add, edit, or delete a captive portal. When you add or edit a captive portal, the portal configuration dialog displays. |
| Portal Connection | Indicates the Interface/Topology that is used for the portal communication. |
| Use FQDN for connection | Use the Fully-Qualified Domain Name (FQDN) of the VLAN instead of its IP address when redirecting clients to the captive portal. This is required for OpenID Connect. |
| Walled Garden Rules | Click Walled Garden Rules to configure policy rules for the internal captive portal. |
| Use HTTPS for connection | (Optional) Indicates that the connection will be secure with HTTPS. |
| Authentication method | Select the local authentication method for the Internal Captive Portal. The
following authentication methods are supported for Internal Captive Portal:
Note: Default AAA provides validation of client acceptance status based on
provided credentials. Indication of a specific role for policy assignment change
is not supported.
| LDAP Configuration | Lightweight Directory Access Protocol. Select a configuration or select the plus sign to add a new configuration. |
