AP Location Information
AP Location Settings for Fine Timing Measurement
These settings provide information about the location of a specific AP for Fine
Timing Measurement (FTM). FTM is used to find (estimate) the distance between the AP
and the wireless client.
LCI
For APs with GPS, the latitude, longitude, and altitude might be automatically
populated. However, you can override these values by checking
LCI Override and
manually entering the following for the specific AP device:
- Latitude
- Longitude
- Altitude
Z-Subelement
Check Z-Subelement
Enable to enter Z-axis information about the AP.
Expected to
Move - Check this setting if the AP is likely to move to a different
location.
Enter these values for the specific AP:
- Floor Number -
Integer indicating the floor the AP is installed on. The range is -25 to
250.
- Height Above
Floor - Number value of 0.0 or greater indicating the height in
meters that the AP is above the floor.
- Height Above Floor
Uncertainty - Number value from 0.0 to 10.0 indicating the
uncertainty in meters about the Height Above Floor.
For
example, you could set the Height Above Floor value
to 0.5 meters, but the actual value could be 0.1 meters higher or lower, so
set the Height Above Floor Uncertainty value to
0.1.
Civic Address
Displays the RFC 4776 Hex
String.
