Custom Application Settings
Configure the following parameters to add custom applications to the L7 Apps list.
Table 1. Custom Application Settings
FieldDescription
GroupInternet applications are organized in groups based on the type or purpose of the application. After you select an Application Group, the Application Name drop-down is populated with application names that are part of the specified group.
The group names are pre-defined standard Extreme Application Analytics™ signature groups. The group names are case-sensitive.
NameThe name of the custom application.
PatternThe Matching Pattern is the URL pattern that is associated with the application (case-sensitive, up to 64 characters).
