After the floor plan is configured, view it from a selected site's dashboard. The floor plan represents placed devices and associated badges that show configuration and performance data for the device. From the Floor Plans view, you can toggle between floors, filter data, and further fine-tune the map display.
To access Floor Plans view, go to Monitor > Sites, select a sight and select Floor Plans.
If one or more floor plans exist, available floor plans display in the right-side pane.
. to zoom in.
 to zoom in.  to zoom out.
 to zoom out.| Status | Description |
|  | AP is in-service, operating. |
|  | In-service, trouble. |
|  | Critical. Indicates that ExtremeCloud IQ Controller cannot communicate with the AP. |
|  | Unknown. AP is unknown to the displayed floor plan based on floor plan filter settings. Typically occurs when the device group for the AP is not selected. |
|  | Unknown. The AP serial number is unknown to the floor plan. Typically occurs when you import a floor plan with AP place holders. For more information, see Use Case: Importing A Floor Plan with Unknown APs. |
|  | Sensor device |
|  | Switch |
|  | Camera AP displayed as circular icon. |
|  | Extreme Defender Adapter |
|  | Ceiling-Mounted AP |
|  | Wall-Mounted AP |
 to manually
      refresh the page anytime.
 to manually
Save your page setting changes. Auto Refresh is implemented at the browser level and therefore will reset any selections or unsaved page setting changes. When using Auto Refresh, select a refresh interval that allows you to complete the operation within the defined interval. For best results, set Auto Refresh to OFF during configuration selections or selection of a large number of elements.Both Associated and Unassociated clients are refreshed, provided they are marked as showing on the Positioning dialog. For more information, see Positioning Heatmaps.
