Extreme Networks APs use the 802.11 wireless standards (802.11a/b/g/n/ac/ax/be) for network communications, and bridge network traffic to an Ethernet LAN. In addition to the wireless APs that run proprietary software and communicate with an appliance only, Extreme Networks offers cloud-enabled APs.
The following ExtremeWireless™ access points are supported by ExtremeCloud IQ Controller. For more information about the Universal APs, see Universal AP Operational Modes.
| AP Class | Supported Access Points |
Wi-Fi 7
Universal World-Wide APs ExtremeCloud IQ or on-premise operation |
| Wi-Fi 6E Universal World-Wide APs ExtremeCloud IQ or on-premise operation |
| Wi-Fi 6 Universal APs ExtremeCloud IQ or on-premise operation |
| Wi-Fi 6 on-premise operation only |
| Wi-Fi 5 on-premise operation only Note: AP3900 series
requires a minimum firmware revision of 10.41.01 (or later) for
onboarding into ExtremeCloud IQ
Controller. Customers
migrating from ExtremeWireless installations or onboarding new
AP3900 inventory to ExtremeCloud IQ
Controller must ensure
APs are running at least the minimum revision prior to
onboarding. Depending on the age of the inventory, this may
require a manual upgrade of the unit firmware outside of the
management framework.
The Extreme Networks® Defender Adapter SA201 is supported.
A wireless AP physically connects to a LAN infrastructure and establishes an IP connection to ExtremeCloud IQ Controller, which manages the AP configuration through the Wireless Assistant. The appliance provides centralized management (verification and upgrade) of the AP firmware image.
For higher transmission rates, by default, multicast is converted to unicast for all Wi-Fi 6 access points discovered by ExtremeCloud IQ Controller.There is a maximum client threshold of 64 clients. Above 64 clients, the AP defaults to broadcasting on a DTIM interval.
