You can set a data transfer rate for a policy.
To configure rates:
- Go to .
- Select Add or select an existing
rate from the list.
- Configure the following parameters:
- Average Rate (CIR)
- The rate at which the network supports data
transfer under normal operations. It is measured in kilobits per second (Kbps).
The supported rate for ExtremeCloud IQ
Controller is 500,000 Kbps.
- Select Save.
