Configure zones on a floor plan to support Location Engine generation of area change events.
Define up to 16 specific zones per floor to determine whether a client position is inside or outside of each zone. Additionally, you can create areas located inside of other areas. A client can only be located in one area at a time.
You must have a floor plan displayed to enable the Draw Zones feature.To draw a zone on the floor plan map:
