| RADIUS Server IP
address | IP address of the
RADIUS server. |
| Response
Window | Determines the
window of time, in seconds, that ExtremeCloud IQ
Controller will wait for a response from the
RADIUS server. |
| Authentication
Timeout Duration | Determines a timeout value, in seconds, for the RADIUS server
connection. |
| Authentication
Retry Count | Determines the number of times ExtremeCloud IQ
Controller will
attempt to authenticate an end user. |
| Authentication
Client UDP Port | User Datagram Protocol (UDP) port number used for client
authentication. UDP needs only one port for full-duplex, bidirectional traffic. |
| Proxy RADIUS
Accounting Requests | Indicates that the
RADIUS server will also handle RADIUS accounting requests. |
| Accounting Client
UDP Port | UDP port number used for client accounting. User Datagram Protocol
(UDP) needs only one port for full-duplex, bidirectional traffic. |
| Shared
Secret | The password that is used to
validate the connection between the client and the RADIUS server. |
| Mask | Determines if the Shared Secret or password value is displayed on the user
interface. Enable Mask to display dots in place of the Shared Secret or password value. To
display the password characters, clear the Mask check box. |
